4.3 help
kwalker63
i have a 1989 sunbird corsir with a 4.3l blown freez plugs. the oil is not milky but can see water drops on dip stick. can you use a 4.3l out of a car to replace it if you swap parts. and if so what car would be best to pull the 4.3l out of ? need some info :confused:thanks
Re: 4.3 help
Ayuh,... A 1989 pickup truck is your Best shot....
Are ya Sure your's is Junk,..??
havasuboatman
Ensign
Re: 4.3 help
I'm with Bond-o.
Before you replace your motor, it may be a good idea to verify the water droplets on the dipstick aren't from condesation in the dipstick tube. Marine engines are prone to get some water in them.
Just a suggestion
kwalker63
Re: 4.3 help
thanks. its the core plugs behind the motor mounts i was told to use the rubber core plugs to check it and if its ok use the brass plugs.
Re: 4.3 help
Ayuh,... That's Correct...
