4.3 cool engine, hot circ pump.. why?
wncrjb
Sorry for the long post, but wanted to give as much info as I could..........
I'm working on a project boat. A 1994 chaparral 18 foot.
I bought this boat with no engine or drive.
I was able to find a used 94 4.3 mercruiser and a GEN II drive with all the plug and play stuff on it.
I installed the engine 2 weeks ago, everything went great, ran good, oil pressure good , temp stayed right above 120 degrees.......
The next day it was hydrolocked, ended up having a cracked block and both heads were cracked......
I had a 1989 4.3 mercruiser engine in my shop, so I decided to install that one to finish out the summer.Sorry, don't have the SN for it, it's missing.
After installing the second engine, I used the circ pump, t-stat housing, manifolds and risers off the first engine since I had no problem with them. They did keep the first engine cool.
Compression is good ( 160 on all cylinders )
new tune up
timing is set
NOW THE PROBLEM:
while running on muffs, using a temp gun,
intake manifold at base of t-stat 118 degrees
top of risers 76 degrees
bottom of exhaust manifolds 95 degrees
inlet hose at power steering cooler 62 degrees ( I have cold spring water )
block at core plug 190 degrees
water pump ( circ pump ) 187 degrees
I removed the t-stat for testing purposes and the results were the same.
I removed the water hose at the power steering pump and checked it. At 1000 RPM for 15 seconds, it got 3 gallons of water.
When I shut the engine off, I can hear and feel water bubbling in the hose going from the t-stat housing to the circ pump, like it's boiling and it is also hot.
My exhaust manifolds and risers are clean with no problems ( that I can see )
Also noticed that the water OUTPUT ( at the drive )is not as much on this engine as it was on the first one.
I'm sure I have blockage somewhere, but am lost on where to begin.
Any chance a bad head gasket could cause this? even though compression test was good.....
I'm sure you folks can throw idea my way that I would never think of.
thanks in advance,
wncrjb
Re: 4.3 cool engine, hot circ pump.. why?
Ayuh,.... The T-Stat......
wncrjb
Sorry, but I removed the t-stat and the results were the same, give or take a degree or two.
wncrjb
Uraijit
Banned
Back-flush each part of the system individually. You will be able to pinpoint your problem area(s) more easily that way.
metro3pilot
Was the intake manifold gasket installed properly ?
some of the head gasket water passages are pretty small could easily be plugged ...
just a guess,
but the water is not leaving the block and thats why it's boiling out at the water pump, so the blockage should be somewhere in the engine
OK,... How about the T-Stat Housing....
