4.3 chev OMC gets hot over 35mph
philbilly
Our chevy 4.3 OMC cobra heats up if I run at 35mph or over. I then have to let it idle or drive slow to cool it back down.
The impeller is 2 years old. The manifolds dont seem hot to the touch....Where do I begin to look for the problem?
(freshwater boat)
Bt Doctur
Re: 4.3 chev OMC gets hot over 35mph
1 Impeller change
2 Thermostat check/replace
3 clogged/clogging riser.
bustermin
Banned
it sounds like your impeller/water pump it beginning to fail, it is pumping enough water to cool at lower speeds because it does not need as much water to keep it kool, at higher speeds the impeller if not straightening out enough to pump enough water thru the sytem. i would change the impeller/water pump and the thermostat.
180shabah
Either slow down, or replace the impeller. It should be done every year anyway.
