jarrod1995
Thread starter- Joined
- Oct 13, 2011
- 47
Didn't go so well, has been running fine before the rubber boot melted on last trip. Replaced Risers, Manifolds, all rubber tubes for the exhaust, and the flappers. Took the out drive off, changed Shift cable and replaced the ESA.
Now it won?t idle, if it starts, runs fine over 1000rpm's give it the gas; not in gear, just cuts out a dies. Get it fired back up and wont throttle up and dies.
Now only in the water, on land it will idle and run fine, hesitates trying to give it some gas, but will run up.
How long with gas last in a tank after it has been treated with Stabilizer, the ethanol kind, I over did it to a point.
