3m -Johnson -evinrude- permatex aviation
Elh5050
Which gasket sealant is best? Should it be used on drive shaft seal and on shift rod bushing and seal? Or grease or nothing?
HighTrim
Re: 3m -Johnson -evinrude- permatex aviation
I swear by the 3M 847
You can put it on the exterior circumference of the seals, but usually not needed there. Grease on the o ring.
boobie
Agree with the 3M 847. You can also get by with Permatex # 3 on the exterior of the seals.
yorab
Ensign
+1 for 3M 847. Available lots of places online. I picked up mine at a brick n' mortar Fastenal.
