3hp lightwin/yachtwin fuel screen
traveller
The shut off valve has a fuel screen/filter. I want to replace the one on my 1966 engine but can't locate a part number for the screen. I assume the screen can be purchased separate from the entire valve. Any suggestions for finding the part number?
1946Zephyr
Re: 3hp lightwin/yachtwin fuel screen
if you don't mind doing a little soldering, then yes. Otherwise, you could find a good used set-up
traveller
I don't have a parts manual so don't know if the screen can be purchased separate from the valve assembly. The service manual says to replace if the screen is gummed up, but I'm not sure if this means replace the screen or the entire valve assembly. From what I can figure out, the part number for the entire assembly is 383688. The cost is about $35.00. I was hoping a screen could be purchased separately.
traveller
Perfect. It looks like the screen is available as a separate part. Part no. is 277187. Cost is $40.00 (ouch) at Marineengine.com and apparently isn't available at BPA.
1946Zephyr
At least now though, you have a complete parts manual for that fine classic of yours. :D
F_R
Well, if you have an extra $40 bucks laying around, that is the way to go. The filter is soldered into the adapter fitting. Personally, I unsolder the filter from the fitting and solder in a roll of brass filter screen. If you want to do that, send me PM and I'll send you a piece of screen.
boobie
Or else take the screen out and put a small inline filter in the fuel line before the carb. I know you can get them.
