3856761
Juhl
Hi
I am looking for the special tool for adjustning the shifting mechaniseme on a DPA out drive - VP tool article no
3856761. Cannot find it anywhere. anyone have the dimension or is there another procduere without the tool ?
/jens
muc
"Retired" Association of Marine Technicians...
I had this tool at one of the shops I worked at, used it once. Waste of time.
As you turn the eccentric piston you will notice it moves in and out as you shift from forward-neutral-reverse. When it's at the most in (half way between forward or reverse and neutral) that's were to do the shimming.
Use the procedure for the type 1 or type 2 shift mechanism. They shim the same as your DP-A
Juhl
Thanks Muc - was of the same opinion but nice to have it confirmed
