jctexas07
Thread starter- Joined
- Mar 20, 2010
- 9
I have a 383 stroker in our boat. It just started leaking oil the other day. Upon inspecting the engine, I noticed oil between one of the heads and the block--atleast there was just a small amount of oil where the head gasket is. I ran my finger down to the oil filter, which had a little oil on it as well. No drop in oil pressure.
Other than that, it was not enough to substantiate the leak, which looked like about 1/4 of a quart.
**UPDATED: I noticed a little oil leakage under the valve covers and noticed one of the bolts was loose--imagine that. I'm going to torque them down and go from there.
I have summit racing aluminum heads and weiland intake on the motor as well. Any suggestions would be great--the more specific, the better. I am not familiar with this engine. Thanks a million. Could it be oil from one of the trim lines, and as the boat is moving, the oil gets on the lower parts of the motor? Clueless here........
