StevNimrod
Thread starter- Joined
- Dec 13, 2008
- 343
Re: 383 Initial Startup Problem
I got the carb apart and put back together yesterday using the combo Tim suggested and the silver springs. If it ever stops raining I'll be able to get it installed and let you guys know how it runs.
The step up springs are down in with the secondary rods. They determine when the rod starts to raise out of the hole. On each side of the carb you'll back off the screws holding down the small plates enough so the plate swings to the side. The plunger holding the rod will pop up and the spring is underneath. I run the pink springs in mine and they seem to give the best response.
