35hp throttle problem
Chevydad
I have a 1977 johnson seahorse and when on the water wont run over 11mph and won't go on plane but when i take the cover off and manually run the throttle it will get it to plane out and run around where it use to run
IDFISHER
Sounds like something is out of adjustment on your throttle cable/linkage and your throttle plates aren't opening all the way. Just had a similar problem on mine and with proper adjustment it's screaming.
Chevydad
Ok i know the cable is adjusted at the engine to where i can't adjust it anymore i was able to see a gap between the roller and the plate when its at idle
Honorary Supreme Mariner
It may surprise you but on most motors there is a gap at the roller and throttle cam.----Do not start adjusting things because they " look wrong " to you.----Check the operation of throttle cable from the control box first.
Spin prop ( assistant required ) while shifting into gear.----Put handle to full throttle.-------Does carburetor open all the way with throttle plate horizontal , yes or no ?
Chevydad
I wasn't going to adjust them new to the engine was just putting out what i seen. Im not around the boat right now i know when it was out i had full movement of the cable when i get back home i will check to see on the throttle plate is horizontal. So i need to put the engine in gear and go to wot.
F_R
One of the cable ends may have slipped on the inner wire. Held by two setscrews (both ends of cable).
Chevydad
No i just got the boat it ran fine the first i put it in the water then this time it started
Chevydad
At wot the plate is not horizontal dose that mean something is out of adjustment
Motor must be in gear to get full throttle.---Is the plastic pin 329197 on the bottom of tower shaft broken ?
