k1llsw1tch
Thread starter- Joined
- Apr 28, 2016
- 5
Hi, all. I have never registered to this site but have mainly used it for research purposes. I am new to the boating world and my neighbor sold me his 16' Aluminum boat with a 35hp Johnson Seahorse with Jack Plate. I still do not understand all the lingo but bare with me here. The boat sat for almost 2 years. He stated that it ran fine before he parked it. I have two plastic 6 gallon tanks. I put new gas in it with sea foam, put it on the water and it would not idle and would just start surging as I gave it more gas. I brought it home and began breaking into the carb. When I removed the front cover to the carb (where the carb adjust needle is) I found the front facing gasket was half there. Replaced that and then bought a carb kit and replaced all he gaskets and cleaned thoroughly with gum off and air. I was astounded at how clean the carb was. Took it back to the river and tuned in the carb and i could get it to idle for a couple minutes and it would die out. I then ran it full throttle and it only feels like i am getting 20%. When i have it on muffs the thing sounds like a race engine (I learned through this site not to go high rpm's on muff's after the fact). Took it back to the river and ran it all day, fresh gas, replaced the fuel lines (internally) and i felt like i was going 10mph at full throttle. The engine doesn't event sound the way it does on muffs. I also went through 14 gallons of gas from 2 1/2 hrs of running at full throttle. Prior to all this, I did replace the spark plugs. I have no clue what i should do next. I had my dad bring his boat who has a 16' alumicraft with 90hp Johnson FI and he even stated that i was not getting the power I should be. Any help would be greatly appreciated! Thanks for providing such a great forum, I have already learned alot!
