SouthCarolina1
Thread starter- Joined
- Jun 17, 2013
- 169
Background: bought a jon boat with a 1986 35 HP Johnson tiller handle. The PO said he went to start it up using gas, gas with ethanol... from last year and couldn't get the motor started. Checked the compression and both cylinders had 125 PSI +/-2.
Now: took the gas line and put it into a can of seafoam. Primed the gas system and let it sit for a few days. Reconnected the fuel line to the gas tank, fresh gas/oil, and the motor started up second pull. I took the boat out for a spin and when I opened the throttle wide open it sounded like it was only half way open. Sounded like it was bogging down but when I pulled the manual choke/primer the motor shot up in RPMs, boat took off in speed, but the RPMs slowly died back to what it was before, like half throttle. One thing I found weird, when I hit a wave and the bow of the boat popped up, the motor increased in RPMs. So I am thinking a possible vapor lock? Float level needs to be adjusted? I ordered a carb kit, fuel pumps, and fuel lines.
So while I am at it, I thought I would replace the water impeller. Before pulling the foot off I drained the gear oil. I have replaced the gear oil in several motors and I have never seen gear oil this black. I found a very small amount of metal shavings. I plan on flushing the gear oil until it comes out clear. The motor shifts in out of gear just fine and stays in gear. I have also marked the prop hub to check for slippage. For the gear oil should I be concerned or just assume the PO never changed the gear oil? If the foot was going bad it would cause the motor to bog down or pop out of gear right? Also, when I was draining the oil I took out the top and bottom plug with a flat head but then I noticed a screw for a Phillips head, what it this screw for?
Thoughts?
Thoughts?
