3rdcoastpowersports
Thread starter- Joined
- Oct 29, 2013
- 4
1984 evinrude 35hp 2 stoke. cuts out with higher RPM's (over 6mph).
Starts right up at the very first hit of the key
132 compression top cylinder
130 compression bottom cylinder
Plugs look good
Spark Jumps 1/2 gap
Rebuilt carb last week
Adjusted throttle linkages and fast idle so that idle timing is within the two points
2 brand new big ass battery's with full juice powering this 14 foot boat.
new propeller
new water pump kit
Exhaust blows lots of water/mist
Weep hole for the water pump pisses out good and is just slightly warmer than the ocean water it sucks.
It sounds like its either loosing fuel or spark. I think its spark.
I squeeze the ball when it starts to cut out/hard miss and it does nothing to help.
So.... fires right up, idles great, give it 10% throttle all is well, 13% throttle all is well, 30% throttle it strait up cuts out (like an old car). It does not die but cuts out and will continue to cut out/SOLID misfire until you reduce rpms.
Observations:
one of the coil packs looks "crusty". it does not have that shiny silicone finish (burnt looking).
plugs look good.
What should I buy to fix it? I will order 2 new coils, wires and plugs just for the hell of it but what the problem?
Plugs look good
Spark Jumps 1/2 gap
new propeller
new water pump kit
Observations:
plugs look good.
