35hp evi trouble
patbanks
approx '90 model, p/pack under flywheel 2 cyl 35hp evinrude. At full rpm after about 30 secs the engine cuts out and sparks intermittantly on both cyl. I think it is the engine protection cutting in but not sure if this model had that. If it does could it be over rev, and/or overheat? Motor will still idle fine and will stop carrying on after about 30 secs. of idling. Wont do it when cold.
Hooty
Re: 35hp evi trouble
I'm not sure if your engine has the S-L-O-W feature or not. Have you felt the engine to see if it's hot or not?<br /><br />c/6<br />Hooty
patbanks
thanks mate but i have worked it out. It does have slow and it was overrevving so it was easy fixed.
