35hp Capabilities
tashasdaddy
Re: 35hp Capabilities
fireman 57, so i am i. why i said to swap the coils.
jimmbo
The reeds on this engine aren't on v-blocks, they lay flat spread out like petals on a flower
DHPMARINE
Obviously you have to fix the fuel problem.
But an 'older' 15 foot tri hull fishing boat sounds awful heavy. Even sounds like the last owner may have added the carpeted deck and all.Heavier.
I'd doubt 35 HP would ever get it on plane.
It certainly isn't a jon boat.
DHP
fireman57
I agree with DHP if it is a tri-hull. In my earlier post I said that it pushes my brother's 14.5ft fiberglass boat about 20-21. It is wider than my fiberglass but it is not a tri-hull, just a plain old boat. Tasha, again you are right on with the spark. Jimmbo, I just couldn't think of a good example of what they look like. You came up with a good one. Just wanted him to check them while he had the carb off.
