35el79a hot head, teppid discharge water ?
relics hunter
It has a new pump, changed the lower oil, rebuilt started, rebuilt carb, new plugs, rewired it. I have no history on it, but so far it starts like a dream and pisses like a youngster. I am at the adjusting stage and I am a little baffled by the temp readings I get on the thermostat cover and side of the head. The water out of the tell tale and exhaust ports is heavy and what I would call tepid, but the temp reading off the thero cover climbs over 162 (which I thought is the high range). When it got to 179 I shut it down. Mean while the readings on the left side of the cylinder head are over 210 for the upper one and only 145 for the lower one
relics hunter
I guess that is not jogging anyone's thoughts. Is it possible there are clogged areas around the top cylinder that is allowing it very little water flow? I know what the channels look like and I am not convinced. I figure I am looking at cracking it open either way.
oldboat1
replacing t.stat comes to mind, two gaskets and t.stat assembly. If it's a salt water motor, likely corrosion (clean passages when in there).
edit: If salt water, may not want to pull head right away, come to think of it -- sheared off bolts a real pain. One gasket, t.stat assembly, clean out passages you can get at, try to flush from the top.... and soak t.stat cover bolts overnight before trying to remove.
boobie
As I told you on the other forum, check the water deflectors in the block for being swelled and blocking water flow.
relics hunter
Well I pulled the head and looks like all the deflectors are bad. The lower left one is barely there, the top one just crumbled apart. Now I have a couple questions for reassembly. I looked up the part and it lists that three #335603 are needed. I picked up some 3/8 " tubing as the replacement and It is a little loose at the top front edge, hope it will be fine. Now for length, I don't have a reference on the part length or a complete old part. The top one is easy to measure should I just assume and cut all three the same. The reason I am asking this is the lower deflectors seemed shorter ( maybe) and I have looked at many other close years and seen some use a shorter length on the bottom two. I know errors happen on the parts lists, I want to get this right the first time. So I cut all three the same length and the bottom two would not go in the same amount, but they do seem to close off the desired area. I cut off the extra and close it up, now if it would just stop raining here in Florida.
