I have an 86 Dixie Super Skier 299 with a Ford 351w engine in it. The engine runs good but somewhere the wiring is a little screwed up. It always cranks strong but every now and then, the plugs won't fire.
The first time this happened, I replaced the fuel filler and had to replace the grounding wire running from the fuel filler to the tank. Since this was a serious issue, I ran a dedicated ground wire from the tank to the battery and that fixed it. I installed a radio next and everything worked fine. The boat sat all winter while I was restoring it. I didn't touch any wiring and after being winterized and sitting for 4 months, it fired up instantly and ran like a champ. A couple weeks later it wouldn't spark again so I just pulled the face plate off the radio and it fired right up. Lastly, 2 days ago, it wouldn't fire again so I completely disconnected the radio and never got it going. However, the very next day it ran....
Does anyone have a wiring diagram for these engines? I'm sure there are some since it's a normal truck engine but I can only imagine those would have hundreds more wires that boats don't have that would make things confusing. My plan it replace all of the wire connectors that I can find in hopes that a couple of them are just corroded and the temperature and weather are affecting them but it would help to know what they all do while I'm in there.
