Re: 350 Magnum EFI - 1995
Warren you need to check the map sensor with a vaccum guage. Determin if it will hold a vaccum. Since you said it backfire it could have burst the diaphram in it. This would set both codes. High map sensor voltage reading, due to no vaccum. The ECU recognizes a variable difference between the two sensors under different throttle conditions. With no vaccum reading from map sensor the voltage will remain at the 5 volt refrence, ECU thinks your at idle, but then realizes TPS voltage is high due to opened throttle position.<br /><br />At idle, high vaccum = low voltage at MAP sensor<br />At WOT, low vaccum - high voltage at MAP<br />At idle, low voltage at TPS<br />At WOT, high voltage at TPS
