fish4striper
- Dec 18, 2021
- 10
Hi,
Hope you guys can help. Both engines start easy and run very good. Then one day last week port eng just stalls as its close to temperature. Started back up but died again. Let it cool down, now wont start at all. Shot starting fluid in throttle and starts up so I figured it was no fuel. Checked pressure at fuel rail, none. Chased around, fuses ok, tried wiggling connections, replaced fuel pump relay and now I get power down to fuel pumps. I tried starting but wouldn't start. Fuel pump runs for 2 secs then stops when the key is turned. Don't get any pressure to the fuel rail. I tried turn key off and forward it pump runs every time for 2 secs. Several times but never get any pressure at the rail.
Is the secondary pump dead and not sending fuel to the rail? Not sure how the two pumps work. If the 1st pumps shuts off after 2 seconds, what sends power to the secondary pump to feed the rail constantly?
Any help would be appreciated. Got to get this running soon to winterize. I'm in the northeast.
Thanks, Jeff
Thanks, Jeff
