iammarcuse
- Oct 15, 2007
- 142
A couple of year old thread but hoping for some responses. I have the exact same problem. Steering is stiff at the start of a turn. Unhooked all the clevis pins, outdrive moved easy and steering wheel moved easy. Steering cable was not binding in tube. Taking the advise of this thread I replaced the cable, which seemed perfect BTW. I assumed things would be fine once I got the boat back in the water. No love. Still sticking a bit when you go to turn. When I did have it all apart I tried to move the actuator valve by hand (like in the video posted in this thread.). It moved, but needed a good push or pull and then the power assist kicked in. How easy should that thing move by hand? It would seem now that maybe that spool valve shaft is binding slightly? idk Thinking of pulling the valve shaft out, but then what? Any thoughts?
