DRAKESLAYER
- Aug 9, 2010
- 17
The 35 hr 2 stroke 2cyl motor, the prolbem is the bottom cyl is not sparking i swtiched coils from top to bottom. Whatever one is on top is working, and whatever one is on bottom is not.
what year and model number is your engine?
when you switched the coil cables did you switch the spark plug cables as well?
dont know the guy said mid 80s it painted so i cant find a model number. could it be the vacum cut out switch
clean the surface where the coil grounds, also trace the wires and look for a broken wire or bad conection.
i will try new washers i hope that is the prolbem
Thanks for the help got spark when i clean the threads. New prolbem it sounds like it want to fire but just wont turn over. I think i put to much oil in the gas. I change the fliter and the fuel lines so i think i put to much oil in the gas so i am going to change gas and put less gas. If any one has any more adive would be awsome thank you
