35 hp johnson.prop
donaldmouse
10 1/2 X11 pitch now with minor pitting.I Want more lift the boat is slow to plane.Motor cv plate even with bottom.wanting power to plane its not a speed boat its a fishing boat 35 hp.planes now with 2 people just slow doing it.
steelespike
Re: 35 hp johnson.prop
Need year of motor. Year brand and model boat.dry weight if possible. Load, motor,people,gear gas etc
Wot rpm and gps speed would be great.Your motor needs to rev freely within its rpm range.
donaldmouse
1979 johnson seahorse long shaft.Its on a 1994 carolina skiff 14ft.acording to what I read About 700 lbs total not knowing what the motor is. 400 people and 6 gal gas 280 boat so a good guess on motor weight I would say 900lbs total.wot, speed, Idk no tach.
steelespike
My info indicate 480 lbs for a 94 1455. Motor is about 121.
It would appear by your weight That a 10" pitch is in order.
Not knowing your wot rpm and gps speed its difficult to know your possible results.
Is slow to plane 20 seconds or several minutes?
donaldmouse
Timed this last weekend adjusting trim pin the best I was able to get is 1 min 10 seconds.with pin in second hole.I also added fins on motor prior to this.Put wife on bow just to see if weight distribution would help no differance in time.
drewactual
since that prop is toast(ing) anyway, due to the minor pitting, would you be willing to experiment?
I'm a big fan of vented props.. even though folks will argue they are for performance rigs with weight and deep pitches, it's my opinion that any engine can gain from them, allowing a higher pitch to be used on a rig requiring a lower one..
assuming that is a through hub exhaust, if you were to drill at the base of each blade through the casing with no larger than 1/4" holes (the base side of each blade nearest the gear housing, and on the blade side you can't see while looking at the prop from the exposed side of the hub), you will find your engine is capable of spooling up much faster...
the concept is to allow a 'controlled ventilation' by exhaust being spilled on the face of the blade, allowing it to slip.. the hydro force of water slipping past those vents as speed and surface tension on the vents increases closes them off when you reach planing speeds.. what it allows is the prop to spin more freely before forward movement happens, which allows the engine to reach it's power curve quicker.. think of it as your prop getting a running start at the water before it bites in fully..
the only problem w/ doing this is how the hub supports attach to the outer casing- if the holes you're drilling interfere with those flat stanchions, you can't tap it...
it sounds, based on your description, that your engine is capable of revving to the rpm range you need, but it would benefit from a lower pitch... the question is if that lower pitch is too shallow, and allows your engine to over-rev.. if you can reach WOT recommended by the manufacturer with the current geometry, then you are a prime candidate in my opinion to tap the vents.... and if it doesn't work? well, you're prop shopping anyway... and your next prop should be lower pitched, and slightly larger diameter to make the difference back up.
donaldmouse
Its not a through hub exhaust.Thanks for the response.I am going to buy a new prop.Spoke with the local marina,they are going to sell me one but give me a bring back so if not satisfied with the performance I bring the prop back for exchange until we get a satisfactory outcome.They are even going to do a wot test on each prop for no extra charge.Think this may be the ticket to satisfaction with a one time expense.Thanks again for the advice it is Greatly appreciated..
Before you invest in props and before trying other props, make darned sure the engine is tuned properly and making all of the power is its supposed to. A new prop is NOT a fix for a tired or mistuned engine.
jimmbo
If it is not a Thru Hub exhaust I doubt very much it is a 1979 35hp. The last 35 hp without thru hub exhaust was made in 1959
