35 HP Gale WOT 7MPH???
Rollinunknown
Re: 35 HP Gale WOT 7MPH???
so ten bucks for one gas tank turned into 15 bucks for 3. I am totally ok with that deal I would say.
Is there anyway you could snap some close ups how you have your throttle and shift cable hooked up?
I have the ends that go to the Throttle and shifter .Im looking for the clips that bolt to the motor and dont allow the cable to slide back and forth.
paraord
paraord
ok so the screw driver is for illustrative purposes because I have not reconnected the motor, its still on the stand. but you start with the cable vertically, then rotate it horizontally to lock it in.
Rollinunknown
Thanks a ton for taking the time out for the pic's i just ordered them yesterday
they should be here any time.;)
paraord
not a problem, hope the screwdriver was ok, it was late and i didnt feel like lugging the motor back on to the boat to connected it all again.
Rollinunknown
yup im just waiting on the clips and im ready to go!
paraord
very good. Im doing a little trailer re wiring and painting which has my motor on hold because well its alot easier to take the boat off the trailer without the motor. But I will get back to it, I have the day off so trailer, then motor generator testing is my plan. But you know what they say about the best laid plans.
paraord
heck I should change the title to restoration of the 35 HP gale and 1965 Duratech. So I pulled up the subfloor last night as well as the transom board, or lack there of. Got a can of gluvit and a nice 80 degree day.:D
campione
This is a great site!
I currently have the same motor, gale 35 hp ob, i believe to be 1960 (35de13bl). when looking for parts, what make and model should i use?
thankc
kc
Ok.
I have replaced the points (.02) gap. I replaced the condensers and the coils. as well as the 5 term ignition. I can't get this dog to kick over for me. It had in the past for a little while but now nothing. The other thing would be that the ignition will not turn the electric start on. I have checked my connections and they are all correct. I ve even checked to all the lines for cracks or anything else. no luck. can some on give me direction. Help lol lol ..
paraord
i dont know guys, maybe i need a different prop pitch? i was only doing 14 today its prob some trim related but i think it might be a pitch thing too what do you guys think
M
mrcrabs
Guest
would be really hard for anyone to tell you with out knowing what rpm your turning at WOT and current prop pitch
campione
Thank you for the info. I changed out all electrical under flywheel!. It was back firing but i made a better adjustment to the gaps and that seems to be gone. i hope. I am having a problem with the ignition. I can get it to start by the key. I can kill it by the key but not start. I have checked for continuity of the two blacks and white. I changed out the ss. I checked the murc switch. I don't know at this point. I know the ignition is correct.
thanks
campione
thanks
