35 HP 3 cylinder Johnson oiler
tws1616
I recently purchased a 3 cylinder 35hp Johnson, the previous owner had taken off the oiler... Ive read in some places where you need to take off one of the fuel pumps, my understanding is one is a suction type pump (on the right racing the front) and the other is a pressure pump (on the left facing the front), it appears the guy re-routed the lines but is it necessary to have both? Can they be taken off and just a regular fuel pump be added? I bought it cheap from the guy b/c he said the powerhead was bad and locked up... it ended up being the lower unit locked up.. I was able to find another one. the motor has 120 compression across the board. Thanks for any help/advise.
Honorary Supreme Mariner
They will run just fine with the 2 pumps exactly as they where when oiler was in service.-----They are just regular / simple fuel pumps and there is nothing special to them because they are on this 3 cylinder motor !------Not sure where these ideas / stories / tall tales come from about having to remove 1 pump.
tws1616
Thanks! I was just curious b/c I read one thing on one site and something else on a different site, this place seems to have more of the better knowledge just from my limited searches. Its ran fine w/ both but wasn't sure if it had to have both since the oiler was removed and was thinking along the lines of simplicity on maintenance (just one to worry about/clean).
These pumps are very simple and rarely cause problems.----------Most of these pumps are replaced for no reason at all.---------Worst thing that can happen is a torn diaphragm and those are easy / cheap to replace.--.
Look it up for the 2 part numbers of those pumps.------They are used from 1980 to 2005 models, anywhere from a 6 hp to a 235 hp model.-----Nothing special about them !!
