matt88
- Mar 17, 2009
- 160
I just purchased a 16ft by about 5.5 ft wide jon boat riveted with the high sides and was wondering about how fast my little 30hp two stroke tohatsu should push it. I had it out for the first time today and didnt have my gps on the boat but it felt like it was going maybe 15mph. Including myself and my wife and fishing gear,fuel,cooler,etc.. It had a load of maybe 500 pounds. I had that same motor on a waterlogged 11ft dell quay dory and that boat was very heavy and hard to get it on a plane but once I did get the dory to plane it would run 22mph with the same load. I know the flat bottom jon boats are not built for speed and the boat did feel light and punchy but the top end wasnt there. I also know the tri hull dory had a much faster hull design but like I said before was waterlogged and heavy. I tried all the different tilt settings and they made a minor difference but nothing major. The only other thing I can try now is to take off the doel fins. I had to take them off when the motor was on the dory as well and that made a huge improvement.It would run almost 30mph without them and a lighter load about 250 pounds. Never meant for this to be so long but should my jon run faster or does this sound right with my current motor,load,etc.. thanks in advance also the cavitation plate is set even with the bottom of the boat,thanks.
