30hp 4 stroke oil
belairbrian
So I just bought this boat with a 30hp 4 stroke. seller says he just changed the engine and gear oil. Said he used Sierra synthetic engine oil. Even gave me an extra bottle. Said it was $12 a quart.
So tonite I read the owners manual and find this:
IMPORTANT: The use of detergent oils, multi‑viscosity oils (other than Mercury or Quicksilver NMMA FC‑W
certified oil or a major brand NMMA FC‑W certified oil), synthetic oils, low quality or oils that contain solid additives are not recommended. (emphasis added)
So should I drain and refill, or is this oil fine? The Sierra Full Synthetic has a NMMA FC-W certification.
wired247
Re: 30hp 4 stroke oil
I'd probably drain it and refill in the next time you are due for an oil change. If it holds the cert its good to go.
