305 V8 Exhaust Manifold
Muete
IMG_20110608_111641.jpgIMG_20110608_111724.jpgIMG_20110608_111659.jpgIMG_20110608_111734.jpgIMG_20110608_111746.jpg
I have been given a small task. Get an engine to a 1983 305 V8 Mercruiser started.
While I was looking at the parts I have available, I noticed the bottom of the exhaust manifold a bit clogged...
I have attached some pics of the manifold...Should I have these cleaned out and if not, should the closed areas cause a concern?
Thanks
Don S
Re: 305 V8 Exhaust Manifold
They are JUNK, replace the manifolds and risers.
Ayuh,... Those are Scrap Iron, Not manifolds...
Muete
I thank you for re-valuating my though.
Muete
Alternate question...
Might these scrap iron hurt the engine so bad the Cylinder #2 would lose compression?
I was given the boat and they said #2 cylinder was bad, but the compete engine is unassembled.
Meuete
Meuete
Ayuh,... They could well have leaked water into the cylinder, causing the problem, Yes...
Don S
If that boat was in salt water (and from the looks of it was) you will be real lucky if the engine turns at all.
