STUDaddy58
Thread starter- Joined
- Jun 29, 2013
- 33
I've got an old (1963-1964) trailer for a fiberglass Lone Star....the boat didn't make it, but it DID donate a trailer, a motor, a fuel tank, and some fittings so that my '63 StarCraft Jupiter could live on....that being said, I'm replacing the rollers on the trailer and can find most of what I need. There are two 3 piece rollers that are located just after the bunks on either side that I cannot find anywhere. Any help in identifying them or where replacements can be had would be greatly appreciated. in the two picture attached, the first shows how they would sit on the trailer, side by side, separated by a "U" shaped bracket that mounts it to the trailer...thought I had pics of them before I pulled them off but can't seem to locate. the second gives you an idea of what each piece looks like on end. the two darker grey pieces are similar, they are about 2 3/8" wide, about 2 3/8" in height, center holes are 5/8", and while one face is flat, the other has a recess of about 1/2 - 5/8". as they sit in the bracket there are fender washers between each piece, and the 5/8" rod that goes through the whole assembly (axle? roller?) has a slot on each end to accept a "C" clip. the lighter center piece is roughly the same diameter but not as wide..only about 2 1/8". the whole assembly is about 7" from end to end. hope some one can help. The iboats forum is definitely my go to place for info and ideas! you guys are the best, hands down...
