3 Johnson 70hp 4 stroke, ongoing issue
Apple Valley Boater
I have had this motor 5 years and 3 mechanics and still have the same issue. Starting out early boat runs great, 5200 - 5300 rpm, starts and idles fine. Some years in the first day, other years in the first week I will be going down the lake full throttle running 5300 rpm then it suddenly drops to 4,000 rpm and starts to load up. Then rough idle, running rich and no high end. I have had three fuel pumps, emptied and cleaned fuel tank 3 times, replaced plugs and has three mechanics that all but have given up. Any known issues with this motor?
gm280
:welcome: aboard Apple Valley. Glad you joined us here at iboats.
Well, I am no pro by any stretch or measurement, but sounds like a cylinder is failing after warming up. Have you checked the spark on all cylinders when it drops RPMs? I would test each spark coil to see if they are firing when it drops RPMs as my first test. Even on the water you can do a quick test to see. Simply remove the cowl and when the RPMs drops, one at a time pull each spark plug wire loose and see if it effects the engine speed. If it does, replace that spark plug wire back on and move to the next one until you find one that doesn't change the engine speed and then check that coil and supporting ignition circuits for that coil... JMHO!
