WALLEYE DIVER
Thread starter- Joined
- May 7, 2002
- 39
Re: 3 hp Got spark Dry plugs Won't start?
I am not outta the woods yet though.<br /><br />I have read that these motors should run cool enough to be able to touch the exhaust plate, and head and not burn yourself. <br /><br />I was letting it run, trying to get the hi and low speeds set. After I had let it run about 5mins. or so. I decided to see how hot it was getting... it was pumping water out of the shaft and I cleaned out the water passages when I had the motor apart, so i figured it was working properly. Well I was wrong... that sucker was hot! <br /><br />The only step that I haven't done is put the new impellar in that came with the kit... looks like I need to do this before I go any farther. <br /><br />Is there any good references on the net or tips you guys might offer on changing the impellar. Is it pretty straight forward? I have a diagram of the lower unit and it looks pretty simple.
