snwwlkr
Thread starter- Joined
- Sep 15, 2010
- 66
Top head in pics is the 70hp, next down is the 75hp, 85hp on the bottom. These were taken off of complete motors I have. Granted I cant guarantee they are the original heads, regardless these are my observations.
All 3 heads
spec for the same plug- L20V
All three show the same size bore in the specs.
Blocks on all 3 appear to be interchangeable except for the head bolt size. All in-letting around the head bolting surface on block for water passages etc appears the same.
1-1970 70hp Chrysler mod# 707HA
-2 piece head with 1/2 inch sized bolt heads and small head bolt holes, 5/16 diameter.
-temp sensor located on block instead of head.
-must remove head to access thermostat.
-Part# on head= 370995 and 369 on side of head.
2-1982 75hp Chrysler mod#756H2H
-2 piece head with 1/2 inch sized bolt heads and small head bolt holes, 5/16.
-temp sensor is integral as one of the smaller 3 bolt heads.
-Part# on head 370995 and just 370 on side of head.
3-1973 85hp Chrysler mod# 857HE
-1 piece head with 9/16 sized bolt heads and larger diameter bolt holes than the other two heads, 13/32.
-temp sensor is integral as one of the larger bolt heads.
-can access thermostat via a dedicated thermostat cover. Head does not have to be removed.
-Only part# on head I could find appeared to read #886
All 3 heads
spec for the same plug- L20V All three show the same size bore in the specs.
