3 blade prop
b29keebird
own a 2005 regal 1800 with a 3.0 merc I/0. want to buy a 3 blade prop with good performance, but would like to keep the revs at WOT at a minimum . I will not be pulling skiers or tubes. What is the best size and pitch prop I should use? Would like to buy an s/s prop. Any help would be appreciated. ty,bob
alldodge
Howdy Bob
Keeping rpms low on the WOT side doesn't save gas or help the motor, it actually is worst on both
To determine what pitch is needed we need some good numbers of what its doing now.
What is current WOT RPM and loaded like normal?
What is the speed at WOT using a GPS?
What type and pitch prop is on it now?
crazy charlie
What you are asking for is a prop specifically for pulling skis or tubes.I dont think that is what you really want.A hi rpm prop is a speed prop which is easier on the motor and better fuel economy.Charlie
b29keebird
Howdy Bob
hi, I own a 40 foot silverton and just bought the regal as a second boat. it came with a 4 blade prop which is dinged. Previous owner took me out for a trial run,but i dont have the answers to the questions that you ask. I wont be able to register or title the boat until the end of the month. (nj motor vehicle). It was a very popular model,so Im hoping someone with the same model boat may be able to help. thanks again, the reason for asking about the wot revs was to keep it in the lower range of revs instead of near red line. Bob
b29keebird
ok,thanks. i just want an idea of size and pitch. youre the second reply and first person said the same thing about easier on the motor. ty,bob
alldodge
He does not want one to pull skiers
The big IF
If the PO change to 4-blade and did it right then they would have dropped 2 inches of pitch. Meaning if the boat came with a 3-blade 19, they would have gone to a 4-blade 17
If they didn't do it right, then it may be same pitch
Hope someone here has the same boat to help
crazy charlie
b29keebird Call 1800 USREGAL and ask for the parts dept.Keep trying until you get someone on the line from parts.Extremely knowledgable.They will be able to give you the original factory specs for prop.Thats what I would use.Charlie​
QBhoy
Might be wrong..but you sure it’s a 1800 ? Not a 1900 or 1700 ? If it’s a 1900, I know of a few with different engines. The 3.0 I knew of can run either a 19 or a 21”, if same ratio.
b29keebird
thank you again, i am hoping to match original prop, bob
b29keebird
1800, ty for your advice.
