ta400man87
- Jun 13, 2008
- 2
I have a 87, 3.7L, 165hp, 4cyl. 470, Ford cst iron head with Alu. Block, with issues. The engine ran fine when I put it away last year. I did an oil change and used the lucas oil additive. The first time out the motor ran fine, it had pleny of power. I was cruising for 10 minutes and then started to hear some weird noises. When I throttled back I started to hear a knock from the motor. Now I the engine bearly has enough power to get on plane, but sound fine at idle and knocks under load.
Now here is what I checked so far.
Dwell is right on the money, it has a new coil from last year.
Timing is advancing (through watching a timing light speed up)
Compression is 1-109, 2-120, 3-136, 4-90, which has not changed in the last 2 years. I also added some oil into the cylinderr chamber of #4 and then repeated the compression test, the compression remained the same, 90psi
Ran the boat on a remote tank thinking I had water in the tank, I also sprayed starting fluid down the carb when the engine was under load to see if the engine was lagging fuel.
When the engine was knocking I pulled each plug from the cap to see if the knocking went away, this is did nothing, the knock did not go away.
I thought maybe the fuel pump, but I would figure that i elimated the fuel pump because i think that is getting enough fuel, when I sprayed in the starting fluid with no response.
The knock does not happen at idle, and only sometimes at rpm without a load. Once the engine is unload and warmed up the knock is really bad.
I am thinking maybe cam, but I would think I would hear that all the time.
Any Ideas or Experiance.
Thanks In Advance
Thanks In Advance
