Bt Doctur
- Aug 29, 2004
- 19,511
Re: 3.7 mercruiser valve lash
I could see those in an hi performance auto application when the block or head is milled. The shims would help compensate
by raising the rocker ,allowing the valve to properly seal in ther head. Your motor does not have adjustable rockers. clearance is done using pushrods. Say for example you had to have .010 milled from the block or head. Now the pushrods would be too long meaning you have to raise the rocker arm.The shims do that.These are the same Ford 460 truck heads with a water inlet port installed.Might find some 460 pushrods that work.
Get or make the tool to do it properly.
