mnowicki
Thread starter- Joined
- Feb 25, 2008
- 14
I have a 1983 Mercruiser 3.0L 140 HP engine with a Rochester 2GC carb. I think i need a new Automatic choke but not sure...
I was out on the lake cruising @ about 3400 rpms (25 mph) went to power down & the engine stalls out??? Took off the carb cover and the top butterfly is loose??? Moving the throttle wouldnt do anything...
Got towed back in to the ramp, drove home and when i checked it agian the butterfly is closed. Hooked it up to the hose and the engine fired right up!
This happened another time before that exact same thing but not on the water is was at home - drove to the mechanics house and it was fine???
Does these things over heat and then after it cools down its fine???
Any help with this would be excellent...
Thanks....
Thanks....
