Well, here I sit up north with 5 kids wanting to go tubing. Boat ran great for about an hour then it crapped out. Couldn't get over 2000 RPM.
History:
First time on the water this year. last Fall did a full tune-up. Cap Rotor, plugs wires, oil change, gear lube change.
this spring I did the water pump change and filled it with fresh gas!
Today when it bogged out on me, I checked the Gas line and check valve. All Good
Pulled apart Carb and checked filter. All Clear.
Changed Plugs: had a new set of GKN in boat.
Took it back out for a run and Same issue!
Came back in and changed the points. gapped to .022", Ran a little better was able to get on plane but it just sounds like crap coming through the carb. I want to check the timing but I do not have a timing light and limited access to part.
Can you give me anything I can check or do with a set of tools. Or if not where should I start when I get home with it?
Thanks for your time! and Happy 4th!
History:
