3.0 runs rough sometimes ??
Brandon15
I have a 99 mercruiser 3.0, runs fine for a while then starts missing and sounds like backfiring, shut it down and sit a few minutes and it will run fine for a few then does it again. Distributor cap and rotor and plugs are all brand new. What should I start checking ?? Also engine temp never gets to hot
Ayuh,..... Welcome Aboard,...... Fuel delivery,..... it's runnin' outa gas,......
Brandon15
That’s what I was thinking but mine don’t have a actual fuel filter it has some kinda stone like thing in it, do those need to be replaced or could my fuel pump be going bad ??
or your vent on the fuel tank is plugged
or the strainer on the pickup tube is plugged
or the anti-siphon valve is sticking
or there is a leak in the line between the pump and the tank
or there is dirt in the carb and the needle and seat are sticking
Rick Stephens
A '99 should have a water separator filter on it from the factory. If not I am amazed at the shortchanging of the buyer for the simplest of necessities. If it has a spin on, pull it off and dump the contents into a clear container and see if anything but pure gas is there.
No way from here to tell, but most likely your carburetor got water or crud in it - water and crud always go together unless the water is filtered out immediately. Only way to fix it if it got water in it is to rebuild the carburetor. If I was a betting man, I'd put my money there. But Scott's list is the more complete one in the previous post. Gotta have fuel, several places it can be plugged up.
Brandon15
Well it’s raining all day today so it will have to wait but thank you all and I will see what I can figure out this week
