3.0 mercruiser problems-carb and temp sender
jaythomas6596
have a 2008 bayliner w/a 3.0 mercruiser TKS still in break-in period, and the first time in water EVER (this summer) the boat was hard to start (needed starting fluid) and bogs on idle to main circuit- shouldn't the accelerator pump "squirt" from idle to main circuit?, 'cause there is not one. also the water temp gauge pegs when key is on-and falls back when unhooked at sender- how to check the sender?- what should it read on an ohmeter? thanks for any help.
Re: 3.0 mercruiser problems-carb and temp sender
Ayuh,... Isn't it still under Warrenty,..??
If so, drag it back to the Dealer...
jaythomas6596
dealer out of business, and only local shop is slammed till 7-26- just trying to minimize time in shop.
