3.0 MerCruiser getting too much fuel in the carburetor won't idle correctly
Birdman1074
How do I adjust the carburetor to get it to run idle it seems to bring gas into the carb even when it's in neutral and off. also the choke linkage does not move unless I move it manually am I missing a link . Basically trying to get it to run smooth in idle . thank you
alldodge
Howdy
Could use a bit more info.
What year is the motor?
Is the carb leaking gas down the throat when the motor is off?
If the choke linkage is sticking it needs to be freed up.
Post 2 more times and then you can upload a pic. We could use a pic of your carb.
Ayuh,..... Welcome Aboard,..... Sounds like it needs a full on rebuild of the carb,....
Which carb ya got,..??
thumpar
Is there fuel in the clear sight tube? If so your fuel pump needs to be replaced.
Birdman1074
Sorry guys i have a 3.0 mercruiser on 93 rinker and it seems to drip fuel into carb even after shut off. Rough idle. Trying to adjust bottom screw. When does choke supposed to move? I did spray throttle body good. Adjust screw for that? Thanks guys i will post pic
alldodge
If your trying to adjust the idle mixer screw (item 25) that is only for air fuel mixing and does not fix a leaking carb.
http://www.mercruiserparts.com/bam/subassembly/30914/1604/120
With the carb dripping fuel it will be time for a carb rebuild. The needle seat and valve in the carb is leaking and causing the carb to flood with fuel. This is what is causing your rough idle as well.
The choke should be closed to within 1/8 inch on the very top edge when cold, like first start in the morning. As the motor warms up it should be full open and not close again until the engine gets real cold, like over night.
Would you rebuild the carb of hire or replace it?
harleyman1975
Ensign
Sounds to me like you may not have a lot of experience with mechanical stuff. I would humbly suggest that you have a pro rebuild the carb. You could fix choke yourself with help from the forum and parts from iboats.
