3.0 merc. Deiseling & spark plug Question
Welder101
I've had my boat to my local mechanic 3 times now for deiseling or run on it only seems to want to start deiseling after it's been ran for more than 4 hours and my mechanic swears it's in time. it's really strange to me. I bought new plugs tonight for it took one of the old ones out and cross refrenced it at O'Reillys. About 6 months ago he said if it started deiseling again turn up the idle it did it again and I went back to the engine bay and I realized I was turning the Air/Fuel screw instead of the idle screw so I backed it back out to where I thought it was previously at and it runs great it's responsive and powerful. But the one plug i pulled out to cross reference was black on the end but the center Ceremic was still fairly white is this normal or do I have it set to rich? And what do you think the deiseling is about? Carbon build up on top of the pistons?
3.0's are known to diesel. especially if you just gone for a hard run, then try to shut it down.
if your plugs are white, its running lean. the black would be soot. you could be lean on idle, and running fine thru the rest of the RPM band since you were screwing around with idle mixture
my suggestion, adjust the carb to get good plug color (tan). then let the motor idle for a minute prior to shutting down, or shut it down in gear.
Scott06
Found similar with my 3.0 after towing skiers (16" pitch prop) or tubers it was prone to diesel. I found It to be hard to get to a good color, over 20 years typically two cylinders wet ash white two were black no matter what I did rebuilding and adjusting the carb. Tried lower float level, plugs looked better but dieseling was worse with a leaner mixture.
Best results I got were decarbonizing the engine with sea foam or GM top cylinder cleaner through the carb bores and letting it idle as mentioned above.
Welder101
Thanks for your advise guys it's really just been bothering me but I guess it's just the nature of the beast! I'll try running seafom through it at every fill up and see if it helps! Thanks again!!
Bt Doctur
Dieseling:
too lean a fuel mixture
too hot a engine temp
too far advanced timing
too hot of a spark plug
A
B
C
D
E All of the above
Not to mention carbon hot spots on the pistons
Welder101
Dieseling:
A
B
C
D
E All of the above
I will start by adjusting the air fuel mixture, since I messed with that in the past. If it's running lean, which way do I turn the air fuel mixture screw BT DOCTUR
Bt Doctur
you open the mixture screw outward to make it richer. If the rpm increases your going the right way. Keep opening untill stable rpm and then adjust the IDLE SPEED SCREW to lower the idle.You may also have to adjust the throttle cable to apply slight downward pressure on the linkage Try to keep the engine temps at 140 or below and keep the bilge blower on while tubing/skiing/ etc. After a hard run try to use fast idle to help lower the engine temp before shutting down to pick up people
Welder101
I will try this tonight after I get off work! Thank you for your knowledge BT DOCTUR
Welder101
Thanks for telling me! I'm changing all my plugs tonight like I stated and then I'll turn the air fuel screw OUT a little and see if it helps! I'll take it to the lake this evening to try it out. I'll post back tonight and tell you if it fixed it!
Welder101
So I took it out this weekend. Long story short just like mentioned above if I let it idle for a Minute or 2 before killing it it shuts off just fine!
Silvertip
Honorary Supreme Mariner
You experienced what nearly every car manufacturer faced in the early days of engine emission controls. Run-on as it was called. The problem was solved by adding an anti-diesel solenoid that was normally energized to provide normal idle speed. When you shut the key off the solenoid dropped out and the throttle blades closed completely thus stopping the engine. Unfortunately the cable operated throttles on boats won't permit this simple addition without a tad bit of engineering. But the solution with the boat is to simply let it idle a bit after a hard run. All is good.
