3.0 fuel pump bolts
cdt785
Hi. I have a 1997 3.0 mercruiser,and I think I have a oil leak coming from the bottom of the fuel pump. does anyone know how much torque the bolts should have? I dont want to over torque them. Thanks in advance.
mpdive
Re: 3.0 fuel pump bolts
Should be 20 foot LBS. Did you just install a new pump? Is the gasket leaking?
cdt785
thanks for the reply. Not a new pump,but it seams like it oily...wet...right under the pump. I had a new timing cover put on in July and there still seams to be a little leak. Power steering and trim oil levels are fine,so i'm going over everything else.
mpdive
You may just want to throw a new gasket in it. It should not be leaking. Coat it with perfect seal or equivelant and torque to 20 ft lbs. Good luck
Fishermark
The pump itself can even leak - pull it and inspect it and the gasket a little closer.
cdt785
Thank you for all the replys. I tightend the pump. The bolts seamed to be pretty loose. I just might invest in a new gasket if I find any more leaks. Thanks again.
