3.0 Exhaust Manifold Removal ?
Rake722
Quick check,
im pulling the manifold on the merc 3.0, removed 2 nuts on studs and 2 bolts under riser but the darn thing won’t budge - is there anything else holding it on or just the gasket making it stick ?
thanks
rake
alldodge
Need to find one more bolt
Its held at 5 points, 2 studs and 3 bolts (a serial number would help)
Rake722
Thanks for the clarification, now to find the hidden bolt
jtsvette
Did you remove the exhaust elbow riser? There is a 3/8-24 hex nut hiding behind it.
