3.0 cobra shift problems!!!!
Duck~killer
It's the electronic distributor which is hooked up to the ESA and the coil pack. The only part that is missing is the cam and switches.
bruceb58
Is it the stock electronic distributor?
Earlier, I missed the part where you said this was a 93. I don't have the schematics for a 93 OMC. You really need to get an OEM manual at some pint to help you with this.
First thing though is to get the shift switch and cam back in there. That one I posted earlier may not work.
bruceb58
Best bet is to search on Ebay.
What is your complete model number? That is important to get the correct manual.
Make sure you get an OEM and not a Seloc or Clymer.
If it's a 93, it will be one of these:
302BMRJVB
302CMRJVB
302CPRJV
Duck~killer
Well I have some good news I found the whole wiring harness with the shift plate and everything. So I should be ok once I get the parts in. I will keep you posted. Again thanks everyone for the help.
