2x10 Instead of 2- 3/4 Ply wood
mercury713
I'm making a jack-plate out of 4 aluminum angles and was wondering if 2x10 pinewood would be strong enough for a 20hp.
Or I have to buy Plywood?
jonesg
Re: 2x10 Instead of 2- 3/4 Ply wood
Ply will not split.
I had a 2x10 split on me on a test stand.
ezmobee
For that application I would absolutely stick with ply.
Cadwelder
You noticed in the link he used plywood, for good reason. The pine 2 x 6 will split especially with a piece that short.
andgott
Master Chief Petty Officer
Will it be strong enough? Sure. At least for a while.
Will you cry when you have to buy a new 20 HP outboard because the old one's on the bottom? Hopefully.
But, you will have saved like $50 or so by not using ply- So you can always put that towards the new motor :)
mercury713
Cool il use plywood. il have to buy some.
Cadwelder
You can get it in 1/2 and 1/4 sheets at Lowes, if you have no use for the rest of a full sheet.
mercury713
Not sure if theres a lowes in Canada( need to update my profile)
They come in pallets and top ones cheaper because of metal straps holding them... even the second or third go cheaper.
35$ first quality
Guess il try plywood thanks for the ideas/knowledge
mercury713
One quick question...
What do I place between the boards to glue them? Is yellow wood glue any good?
Bob_VT
You can use gorilla glue ;)
texasabil
I have got to say that is great stuff!!! I use it when I build cabinets and you let it set there for a hour and notice its cut wrong you will break it trying to get it OFF!!!
