2hp oil leak
msoclr
I have a 2hp evinrude, E2RCOC, which I believe decodes to an '85. There is evidence of oil leakage on the downtube from the powerhead. I'm wondering if this is normal? Perhaps a buildup of the fuel that leaks out of the carb when the motor is tilted? I'm not talking about the oil marks below the exhaust relief, it is above that.<br /><br />Thanks.
D
DJ
Guest
Re: 2hp oil leak
It probably won't hurt anything as long as exhaust is not leaking along with it.<br /><br />Take a close look at the powerhead to leg seam with the engine running.
