I recently obtained a 2HP Johnson with no identification Plate on it. It has separate Fuel Tank and Motor Cover. I believe from checking as much as I have that it is an early 1970's Model. I have checked by parts numbers on early 70's models on different Parts Sites and the only matching one I have found is for the Magneto Flywheel My serial number GT-580892-62, Parts I have found have a number 0580892 FLYWHEEL. My Cylinder Assembly Number is 383371. My serial on the housing that holds the Spark Plug is 313513. My Carburetor Float chamber serial Number is 313723 with a G on top of that and a 2 under it. My Cover Mounting Bracket serial number is 316472. There is no plate on the Clamp but the latch for mine has the serial number 31395. There is a Circular Metal Piece on the motor with the number C0048635 on it with the Letter M over it. This sure makes it hard to tell what Year it is but hopefully someone here will know. Thanks for any help. Wayne
