28 hp johnson type sv carb
heyttown
Ok folks as in couple of my other threads, I have been working on my carb. I got the needle valve pretty close and it still wants to stall at around 5mph.anythings besides this 5mph area works great, Now when I try and slowly throttle up it will bog down and try and stall, at that time I will hit my key(kinda like and automatic choke) and it recieves the gas and it goes, so it sounds like at that throttle it is lean on gas. I adjusted the needle almost to the point where it was running very rich, just a touch before it runs like crap, so its plenty of gas but it will still bog down like its needing fuel at the 5mph range, any ideas on whats next?
Joe Reeves
Re: 28 hp johnson type sv carb
It sounds like something may have been overlooked within the carburetor, such as the brass fixed high speed jet perhaps? Curing the problem by hitting the choke/primer would indicate the carb is running lean. Depending on which carb you may have on that engine (norma=single needle), the adjustment procedure follows.<br /><br />(Carburetor Adjustment - Single S/S Adjustable Needle Valve)<br /><br />Initial setting is: Slow speed = seat gently, then open 1-1/2 turns.<br /><br />Start engine and set the rpms to where it just stays running. In segments of 1/8 turns, start to turn the S/S needle valve in. Wait a few seconds for the engine to respond. As you turn the valve in, the rpms will increase. Lower the rpms again to where the engine will just stay running.<br /> <br />Eventually you'll hit the point where the engine wants to die out or it will spit back (sounds like a mild backfire). At that point, back out the valve 1/4 turn. Within that 1/4 turn, you'll find the smoothest slow speed setting. <br /><br />When you have finished the above adjustment, you will have no reason to move them again unless the carburetor fouls/gums up from sitting, in which case you would be required to remove, clean, and rebuild the carburetor anyway.<br />-------------------------------------------------- <br />(Carburetor Adjustments - Two Adjustable N/Vs) <br /><br />Initial settings are: Bottom high speed = seat gently, then open 1 turn out. Top slow speed = seat gently, then open 1-1/2 turns. <br /><br />Setting the high and low needle valves properly: <br /><br />NOTE: For engines that DO NOT have a shift selection, obviously there is no NEUTRAL position. Simply lower the rpms to the lowest setting to obtain the low speed needle valve adjustment.<br /><br />(High Speed) Start engine (it will run pretty rough), shift into forward gear, take up to full throttle. In segments of 1/8 turn, waiting for the engine to respond between turns, start turning in the bottom high speed needle valve. You'll reach a point whereas the engine will either start to die out or spit back (sounds like a mild backfire). At that point, back out the needle valve 1/4 turn. Within that 1/4 turn, you'll find the smoothest setting. <br /><br />(Low Speed) Slow the engine down to where it just stays running. Shift into neutral. Again in segments of 1/8 turns, start to turn the top needle valve in. Wait a few seconds for the engine to respond. As you turn the valve in, the rpms will increase. Lower the rpms again to where the engine will just stay running. Eventually you'll hit the point where the engine wants to die out or it will spit back. Again, at that point, back out the valve 1/4 turn. Within that 1/4 turn, you'll find the smoothest slow speed setting. <br /><br />When you have finished the above adjustments, you will have no reason to move them again unless the carburetor fouls/gums up from sitting, in which case you would be required to remove, clean, and rebuild the carburetor anyway.
heyttown
Thanks joe, well what I did was I have only 1 needle valve, so I lightly seated it, and backed it out 1 1/2 turns, went and put it in the water and ran around under load, it does what I had explained above, so I gave it 1/4 more turn counterclockwise, and it still did the same, I figured if hitting the choke added gas, it must be starving for fuel at that rpm, I ended up turning the screw 2 or 3 more 1/4 turns ( I cant rememeber exact) and it started running very rough, so I turned it back(clockwise) just enough for it to run ok, still wasnt the smoothest running at idle but I wanted to make sure I would feed it plenty of gas, went for another spin and still bogged down and stalled at the same 5-6 mph, it worked if I hit the choke, if I turned the screw and opened it up anymore the motor wouldnt run, so it was gettting plenty of gas... I ended up putting the screw back at 1 1/2- 1 3/4 turns somewhere in there, it ran the best around there, but I still have to hit the choke if I idle up slow enough or it will stall, Now when I am full throttle I can slowly back off the throttle and eventually run at that speed, but I cant from a stand still position. I will be away from the computer all week, I hope this can be fixed on my own, I hate the thought of something I can do myself to pay someone $70 an hr to work on.....................
