275 outdrive
mazzen66
1986 Volvo penta 275 outdrive, I was told to put sae 90 gear lube in . Is this correct. If not what type
no704
Don't think that is right. Mine takes engine oil.
mazzen66
Perfect, I thought so , it's only a single prop, so 30wt engine oil is it. Thank you sir .
-JR-
Is it a 275 or a 270 . Do you have an inboard motor or a out board motor
mazzen66
Inboard aq125a engine with 275 outdrive already put 10w 30 in on advice from another. I'm I good still? Thank you
mazzen66
Now I have it going , I have another question, I have started to here a high sqweek like a belt but worse. I just replaced the alternater is it possible that when tightening the belt and after use could it be the water pump? Also alternater gets hot before the engine does.the pulley on the water pump has a little wiggle by hand but not much. The sound get louder and worse when reving up the engine. That's new and loud. Thanks for any ideas?and of course you're time .
no704
Keep a close eye on the temp gauge. Drive it like ya stole it. Problem will become more apparent.
