270 outdrive upper unit information
LHUDSON
I just put new bellows on my 270 outdrive.Im putting the upper unit back on and I noticed a larger diameter,thinner shim that is damaged.I guess what I am wondering is how many shims are there between the upper and middle units?
LHUDSON
How many shims in upper unit on my 270 outdrive?
I am replacing the bellows on my aq125a/270 outdrive.I was told not to loose the shims that are in the upper unit.Are there only two shims in between the upper and middle unit?
LHUDSON
does anyone have a link to information on all the parts that are on a 270 outdrive upper unit?
captmello
Re: How many shims in upper unit on my 270 outdrive?
the number of shims varies. If you have the shims that were there, you can only assume without measuring, that they are correct.
Re: 270 outdrive upper unit information
Ayuh,.... Please keep yer questions in a single thread for this topic,...
postin' on this thread will briong it to the top, No need to keep startin' new threads, it leads to Confusion for everybody,...
Thank you,...
LHUDSON
Thanks.The shim is from the upper unit number 42 on the exploded view.I must have damaged when I was trying to get the upper off.I was using a flat screw driver to separate and probably went in a little to deep.What happens if I run without it?
captmello
Can you flatten it out or cut off the bad spot...Either way, my answer still stands, measure it and order a new one if you must. Running without it is not an option imo. Do it right.
LHUDSON
I had to cut about two inchs of it out.Its not a connected full circle.I can put it back in its place.Do you think it will still serve its purpose.
captmello
How much is left? two inches out of how many? I guess if I was going to use it that way, I would cut it again and put equal pieces on each side, so there isn't an area with a large gap.
