25R76E water in carb
Wayne6_7
I recently purchased a 25R76E. I have cleaned carb. tuned up and runs great for about 10 minutes, then starts getting water on plugs and in carb and intake. There is a small hose almost below the carb in the intake going around the side to the crankcase. Moisture is in this hose and seems to be coming from the intake. Is there a water jacket that a leaking gasket can cause this? 123 and 125 lbs of compression
kbait
If there's water in carb bowl, you have water in your fuel.
F_R
Honorary Supreme Mariner
I think that much water in the fuel would prevent it from running at all. I say you are ingesting cooling water into the crankcase. Probably a leaking or holed exhaust cover on the side of the cylinder block. But also could be a badly leaking lower crankshaft seal, or a blown head gasket. Whetever it is, it must be repaired right away. That water will rust and destroy all the bearings in the powerhead. In fact, overnight if it is salt water.
